Lance Cheney
Hellow everyone. I'm in the process of putting on a set of IPT coilovers on my SHO (and finding problems with a few pieces of the kit, but that's another story).
I have a question on the rear mount. The stock rear mount is a big cup, with a painfully recessed strut mounting location, and the strut extends through the lower spindle about 4-5". The coilover kit duplicates that by putting a thick aluminum washer on top of the mounting plate and using longer bolts.
Is there a point to this setup, other than to 'look' like the OEM one? If I didn't use the spacer and then mounted the strut about the same amount higher in the knuckle, this would give me functionally the same results (once I readjusted the camber for the longer pivot length). It would make future swaps (spring or Koni insert) a lot easier too, as you don't have to pull the housing out of the knuckle as far.
Just wanted to make sure I wasn't missing something important. I'm pretty sure the struts will have some clearance at the top still; it would still be adjustable although the adjuster **** obviously won't fit on anymore.
At the very least, the spacer could be cut down.
-Lance
-Lance
