Rear quarter panels?
Pitbull Kustoms
Edmonton Alberta Canada
Just wondering if there is a sorce for getting a rear 1/4 Rh for my '89?
I live in Canada so you can imagine what the winters have done to these cars. Finding one in a wrecker usually ends up with the same result, rusted quarters. Anyone got a suggestion?
Thanks in advance!
SHOtimer
#2910
Santa Clarita, Ca
I think that they are readily available aftermarket - Ford might still have them. I know that Ford still makes the Gen II ones, because I have one on my car.
Doug
TYSHO
Earth
Doug
You mean they make the rear panels for our car? I knew they were welded into the body, so how does this go about? Just wondering because I need one myself.
Minnesho
i was wrong
MinneSHOta
Exactly, you drill out the spot welds, do some cutting and weld the new one on. Not a backyard job, unless of course you feel comfortable with it and know what you are doing.
SHOtimer
#2910
Santa Clarita, Ca
When I was rear ended a few years ago my passenger rear quarter panel was damaged. I had made clear to the body shop that I only wanted Ford parts. I would stop by occasionally and check out the work, I saw the q/p when it came in. The cut the old one around around the seam for the back door, and weld the new one into place.
Doug
RStalveyARFF
too many shos
Georgetown, MA
well the 1/4's are still listed on Ford's online parts catalog so I'd say they're still available. At ~$325 though...
TYSHO
Earth
Did it include the part number? I haven't ran into an online website that list Ford body parts with the part numbers. If I can get the part number, I'd rather use that then the piece I cut off from a parts car. :nut:
SHOtimer
#2910
Santa Clarita, Ca
I'm going to be goin home in two weeks, I can pull out my invoice for it and get you the part number.
Doug
