Probably rotor...
c_olcott
Lynn, Ma
Ok, I hear a light "rubbing" sound from my front drivers side tire when I make a right turn. The sound is very faint and the wheel only needs a very small turn before the sound starts (maybe 10-15 degrees). There is no sound while making a left turn or driving straight. Also the faster I'm moving the faster the sound happens. I havn't taken the wheel off yet because I don't have a garage to go to and it has been COLD and snowy since the noise has started. If there is anything specific, aside from warped rotor, I can/should look for let my know.
Thanks in advance!
Chris
<small>[ February 10, 2003, 01:41 PM: Message edited by: c_olcott ]</small>
projectSHO89
SHOless In St L
Wheel bearing. If you replace it now, you will only have to replace the bearing. If you wait, you will also need the hub and your parts cost will go from about $25 to almost $90 or more.
Steve
DavidT
TN
how hard is it to replace a wheel bearing?
