Part number
Art5
white plains, NY
where can I find Part Numbers for some interior parts?
Towing company damaged my interior plastic and since I'm taking it to court, i need part numbers for damaged parts. I've tried fastpartsnetwork and they have everything , but part numbers for these parts.
93rev2sev
Hockeytown
Part numbers are on the parts. Look for raised lettering on the underside of anything injection molded.
Art5
white plains, NY
I'm seeing door moulding part numbers on fordparts.com
You kinda led me into the right direction, thank you. It is crazy to find part numbers from there though. But i still cannot find weatherstrip for the driver's door. Anyone knows part number for weatherstrip?
fast Ed
Ford lover
Caledon, Ontario, CANADA!
What year is your car? If it's a Gen 1, the door opening weatherstrip for the left front is E7DZ 5420709 A. Gen 2 is F4DZ 5420709 A.
cheers
Ed N.
AREA 91
PA SHO SHOP
Area 91
cheers
Ed N.
Can someone verify 100% that all 86-95 door weatherstriping is the same?
How about the trunk?
Art5
white plains, NY
thanks guys. By the way, do they still sell weatherstrip for the trunk or what to do so that water would not get inside the trunk
AREA 91
PA SHO SHOP
Area 91
The trunk seal itself may be damaged and need replaced.
Another spot that leaks in the trunk is from the tail light housings.
You can apply some RTV where the tail light housing meets the body. DOn't forget to go around all the studsas well.
frosho
WOLFMAN
Tyngsboro, MA
I had problems with water getting into the trunk in both of my SHOs. Neither one was caused by the weatherstripping. There are a couple spots behind each taillight where Ford used a sealant on the creases/edges. Mine were leaking from this area on both sides of the car. I spent a half hour ripping the nasty old sealant out, cleaned the surfaces, and applied some household window sealant. Haven't had any moisture problems since.
Edit: Beaten by Brian. :rolleyes:
fast Ed
Ford lover
I don't think they are the same, the OEM numbers are different. Trunk weatherstrips show different as well. E9DZ 5443720 A for Gen 1, F2DZ 5443720 A for Gen 2.
cheers
Ed N.
TYSHO
Earth
Go to your local dealership with a case of beer and have a parts guy pull it up for you.
Art5
white plains, NY
Or p.m. me a list as I already offered, and I can go through it as I have time. (21 year Ford parts guy) ;)
cheers
Ed N.
Thanks for offer of help.
1FALP54Y0SA151610
It is the plastic on the floor by the door on the left side, i think they call it pillar trim and the front part is by e-brake pedal, i think it is called cowl.
Art5
white plains, NY
Does anyone know what size are the bolts on front engine mount? I don't have one at all.
kumba
Tampa, FL
Weird, I put in the VIN from my '95 ATX and it tells me it doesn't support that VIN. I can still select a '95 taurus without issues though. Weird.
Art5
white plains, NY
The same with me.
But i need to find out what size are those damn bolts before I start doing the job.
