New to forum
Phil1010
Vermont
Image Image Bought a 95 atx sho with 93000 about a month ago. Came with maintence records also been going trough them recently
Welcome, and congrats! I would check when fluids were done. ATX survives on regular changes for sure, no more than 60k in between, preferably much earlier. Think about upgrading the lines for a cooler running trans. Power steering fluid check too.
Phil1010
Vermont
thanks any other maintence i should check or be ready for? I was debating uploading the records to see if something hasn't been done. There's a receipt for a 60k I'm hoping it was a complete 60k job as I couldn't tell 100%
zoomlater
Seattle, WA
Phil1010
Vermont
Here's the invoice for the 60k done at 65000. Looks like Ted Britt out of fairfax Virginia did all the work on this car.
Image Image
Phil1010
Vermont
Here's the ten first invoices should be in order.
zoomlater
Seattle, WA
It looks like they replaced the spark plugs and serpentine belt along with other things during the 65K service. If they had done the full front service it would have shown a timing belt, water pump, crank seal, etc. Looks like the car had regular oil changes so that is good to see.
Phil1010
Vermont
Thanks I didn't think it was a complete 60k. I'm almost 100% sure the guy said they changed the water pump and timing belt when they slapped on this years sticker before they sold it.
Phil1010
Vermont
I had more service records but they were to large to upload and I have not had time. Mostly just it being serviced.
zoomlater
Seattle, WA
Does the water pump look new, if they recently changed it then it should look clean. On my ATX, I didn't have the front service done until 90K and that was due to a small coolant leak (which wasn't from the water pump).
Phil1010
Vermont
Looks clean but than again the whole engine looks clean. I'm not sure I can say I'm 100% sure it's new.
Image Image
