Jr's Sho
First of all, I have a cookout to go to in a couple of minutes so I haven't had time to try and diagnose my Sho. Here's the story, I'm hoping someone can point me in the right direction. I was driving and noticed my temp. gauge at the top of "O", where it has never been. This is on my White 1993, which has always been in the "A" to "L" area and never goes any higher. My A/C began to get a little warmer so I shut it off and pull into O'Reilly's. It was at the top of the "NORMAL" now. I checked the coolant tank and it had some in it. I loosened the cap a little and it shot out some hot coolant so I left it alone. There was no leaks at all so I don't think I'm low on coolant, this car was running perfectly fine before today. Anyhow, I ended up limping it home a couple of miles, never letting it get to the red zone, just a little short of it. My CEL came on 2 times when my gauge got to the top of the "NORMAL" and my oil light flickered at one time when my car was idleing at 800rpms in the parking lot. I then shut it off and restarted it but the oil light didn't come back on at all on the way home. Just thought I'd throw that in. My two codes I got are 117 and 219. One is a ECT code and the other is a timing ******** to 10 degrees or something. Any help would be appreciated, are the codes involved at all with the car overheating? I'm thinking maybe thermostat or lower radiator hose collasping. Thanks.
