94SHO_Norfolk
I wanted to replace the stock paper air filter with either a drop-in K&N, or fab up a Uni foam pod filter into the stock airbox. Looked up some info on K&N's and Uni's website, and found the following. K&N has a drop-in tray filter, part # 33-2040, $54 retail. Uni has a pod-style filter that I could've mounted in the airbox lid, around the metal intake piece with the screen on it, part # UP6350ST (3.5" ID x 5" diam x 6" long), $37 retail. I checked the local auto parts stores around here, and none of them carried the K&N filter, it's a special order. So I went down to the local motorcycle parts store, that carries a bunch of Uni filters, but they didn't have this particular filter either. So I thought of another alternative, and this is what I came up with.
I removed the stock paper filter and took it inside the motorcycle parts store, and was comparing it with some of the Uni foam tray filters they had. Well, I saw this one on the shelf that looked pretty darn close in length and width to the stock filter, so I pulled it down and set it on the floor, next to the stock paper filter. To me, they seemed to be the same in width, but the Uni filter (part # NU-4110, $32 retail) was a little shorter in length, plus it had rounded corners, not straight ones like the stock filter. I decided to roll the dice and buy the Uni tray filter, and see if I could get it to work.
http://i803.photobucket.com/albums/yy319/socal1200r/1994 Ford Taurus SHO/UniFilter1.jpg
http://i803.photobucket.com/albums/yy319/socal1200r/1994 Ford Taurus SHO/UniFilter2.jpg
So I get home and start the process of seeing if this Uni filter would work. I pulled the lid off the airbox, removed the stock filter, and set this Uni filter down on top of the airbox bottom. The sides were wide enough to rest on the airbox bottom, but it was a little thicker than stock, so I had to move the Uni filter towards the front of the airbox, in order for the rear of the airbox lid to angle into its fittings on the airbox bottom, which ended up leaving a small gap along the back of the airbox.
I didn't think this was a good idea, so I decided to cut up some window screen mesh material I had, and used the stock paper filter as a template. Before I did this though, I oiled the Uni foam filter with some regular cooking oil spray I've used on other Uni foam filters, and let it soak in. I set the stock filter on top of the mesh, and cut about 1/2" wider all the way around. I then took some paper towels and soaked up any excess oil from the Uni filter, and walked back out to the car. I put this mesh under the Uni foam tray filter, then wedged it inside the airbox bottom, so the mesh was now covering any gaps, then put the airbox lid on.
The car started right up, didn't throw any codes, and shouldn't oil up any sensors along the intake tract since I soaked up any excess oil with the paper towels. I took the car for a short road test, and all is well. It sounds a little louder on the intake side, and seems to pull a little harder, especially above 4000 rpms, but that's just my seat of the pants dyno.
In any event, I wanted to pass along an alternative to the typical K&N drop-in filter "upgrade". From my experience with using K&N oiled gauze and Uni oiled foam filters on motorcycles, the Unis seem to flow more air, and filter just as well, if not better, than K&N's. Plus, they're washable just like K&N's, but for most applications, are considerably less money.
