How many bubls in Gen 2 Guage Cluster
ForcedSHO
Stupid SHO
New Jersey
I have a few out already. The coolant temp lights are out def and the low fuel light. Trying to figure out how many I should order. Want to replace them all at the same time and do my white face guages.
The cluster is easy to take out just time consuming.
Possible replacement I was thinking about was 2pcs 161 168 194 W5W Inverted LED (White) Wedge Bulbs
Taken from Sylvania
Instrument-general
161
194
37
Check engine indicator
194
Hi-beam indicator
194
37
Seat belt indicator
194
37
Brake warning
194
Directional signal indicator
194
Racer X
SHO Pilot, Retired
Connecticut
Just stick with 194. There are 5 general illumination bulbs, and then whatever other indicators there are.
Bear in mind, some indicators have a small transient voltage at all times, and as such replacement with an LED will result in a persistent indicator. I want to say that the battery light is one in particular, but don't quote me on that.
zak
east of Hartford
How does one r&r the bulbs? close to half of mine are dead.
Racer X
SHO Pilot, Retired
Connecticut
Two ways to replace the bulbs:
Remove the face and gauges while leaving the cluster installed, and access the bulbs that way. Or, remove the cluster assembly from the daashboard, and remove the bulbs from the sockets at the rear.
