ok wow...after 4 hours of struggling tonight, we got all the suspension out...and I think I might be the first to say that the front was a helluva lot worse than the rear...front took us 3 hours, rear took an hour...whoever last messed with the suspension screwed up the front strut bars and overtorqued the bolt on the frame, and then the bar seemed to be angled wrong and wouldnt let the spindle slide down far enough to remove the strut, so we had to disconnect the lower control arm to get the spindle off...crazy ****...the rear came out no problem at all...and then the funny part...I happen to have the rear assembly with that large lead washer in it, so at first Terry was just gonna take it to work and use the impact wrench, but we decided to be ballzy and try something out...we took the vice on the workbench and clamped down the strut/spring sideways, took a breaker bar with I think it was a 13/16ths socket to the nut, and used a pipe wrench on the cartridge to hold it still (there were holes in the dust covers) and boom, broke right loose and then we compressed the spring and pulled the nut off...crazy easy...now wednesday the Eibach/Koni's will be here and I'll be one crazy happy dood!
