tery
Silvia survived the purge- summer car
Hi, I've got the same problem in more than one sho where the cover isn't connected at the back and I can't figure out how to remove the front to repair the switch that has been pushed in. The back is hanging off both of them but I don't see a clear clip in the front and I don't wanna break it off to get it off and just have another mend to do. Anyone experienced with this one...I'll bet someone is, Looks like a common problem with the interiors.
btw, I used crest toothpaste from a you tube to clean headlights on my daughters little geo lights and although it didn't look as good as what I see here from the progressive grit sanding, it was a big improvement. Just a quick fix till you feel like spending the hours to great that showroom look.
Thanks in advance,
Terry
Thanks in advance,
Terry
