quadmasta
Anybody know where I can get any of the obsolete parts for the head rebuild? Shims, rear timing chain, timing tensioner etc?
Thanks a ton
Brian
Thanks a ton
Brian
I thought "timing chain" was referring to the timing belt doh I didn't even think about the shims being available through bike shops (since it's a 6 cyl bike engine).sdpatt:
The shims are available through Ford, SHO NUT, other SHO specialist shops and even Yamaha bike shops. The timing chains and tensioners are also available through Ford, SHO NUT, FordPartsNetwork.com other SHO specialist shops. Have you looked for these parts yet? Just click on the SHO advertisers in the Forum's header.
I'm just looking for new parts, worst case scenario. Since I'm going to TT my engine, I need a 3.2L oil pump, new is best but I'd take a rebuild.sdpatt:
Unless the timing chains are damaged or the tensioner's rubbing blocks are worn down to the metal plate, they are certainly able to be reused.
So the engine bay can eat all the wrenches it wants but I can't fit a turbine in there? We'll see. The T28/T3 turbo I've found that I'm going to use are very small (stock Mitsu Eclipse GS-T)FOR SHO:
Your going to tt your engine? With a taurus? TT wont fit on the sho. The only tt sho is in a probe body. I hope you have a beefed up tranny...
