JimN696
Engine Codes and Problems SD Patt, remember me?
I haven't posted in a while, but I have been having some problems with my 94 ATX with about 96K on it. Every once in a while for the past year after a full throttle run, the check engine light would come on. It happened so infrequently, I ignored it. Last week I cleaned my K and N panel filter and re oiled it. A few days later, I started the engine cold and made a short trip to the store. The check engine light came on. I shut off the engine and tried to restart it, but it wouldn't start. After I cranked for a few seconds a few times, it started, but ran very rough and the tachometer was dead. The check engine light was on again. I shut it down, went in the store and did some shopping. When I came out the car started right up and ran fine. The tach started working within a few minutes, but the check engine light comes on more often now. I took the car to my local Ford dealer. No one there really knows these cars, but they read the codes for me. This is what they got: 176, 212, 214. The dealer couldn't really interpret these so I went on a website and got these answers: 176: O2 sensor not switching; system is or was lean; left or front. 212: Ignition tach signal was erratic (module, wiring) or Spout circuit fault. 214: Error in cylinder ID (CID) circuit or signal.
So what does it all mean? I understand the O2 code and it probably is due to a failing sensor but what is the spout circuit? The tech at Ford told me that the 214 error may mean a faulty cam position sensor. Is that true and is there a way to check it if it's faulty. What will happen if I don't fix it? Thanks for the help, folks.
