Code 219?
genob2
anoka
What is a code 219 mean? SPOUT signal defaulted to 10 degrees BTDC/ SPOUT circuit open. Also have code 213; spout circuit open?
Troywakeling
Winterport, Maine
I would check to see if one of your spouts are unplugged. Its a little plastic cap plugged into a harness back by the ground wire on the back of the intake, Also theres another one by the air box/abs pump. Any loss in power? The cars probly running in limp mode. This thread should explain everything you need to know.
http://www.shoforum.com/showthread.php?t=56278&highlight=SPOUT
genob2
anoka
Checked SPOUT connectors. They're fine. Still have the same codes. Any other suggestions?:
