Code 211...Any suggestions?
SHOByrds
Virginia
Not sure exactly what this is/means. I'm sure I can fix it, just need some guidance.
Thanks
SHOByrds
Virginia
Wait..seriously? I have already done that....went through **** with the original sensor makin my car shut off when the engine warmed up.....So since i replaced the crank sensor about 8 months ago now what.
220ksho
Gen I bias
Oxford (White), MI
Are you still having symptoms? Is it possible that the code is still stored in memory from the last time. I doubt it, since the battery was probably disconnected for some time. Just a thought.
Maybe the earthquake jostled its memory. J/K
SHOByrds
Virginia
I replaced the water pump a few months before i did the CPS,
And i haven't had any symptoms of a bad cps ever since i replaced it.
I have also had the battery off a few times.
WHEN it was bad my symptoms were--the rpms would drop completely and the car would spudder/turn off
What are other symptoms?
