LookAtThatSHO
Who's SHO Daddy
My check engine light has been on for nearly 30,000 miles. I believe it's on because of when I did my y-pipe upgrade, my buddy took one of the O2 sensors out and left it hanging by the exhaust and it melted some of the plastic on the sensor, so when we re-installed the check engine light came on. The sensors have since been changed and new ones installed after the upgrade, but the Check Engine light has remained on ever since. Hooking the CPU up to a reader shows me that it's complaining about the O2 sensors, but I know they aren't the culprit. My question is, does the CPU need to be refreshed in order for the light to finally go out?
Also, My air bag light has been blinking for over 50,000 miles now. Yes, my instrument cluster has looked like it's been Christmas for a long time now.
I plan on fixing the problem on why it has been blinking here shortly. My question is, after fixing the problem, does the CPU also need refreshing before it will stop blinking or should it go out on its own if everything checks out?
Thanks,
Mike
I plan on fixing the problem on why it has been blinking here shortly. My question is, after fixing the problem, does the CPU also need refreshing before it will stop blinking or should it go out on its own if everything checks out?Thanks,
Mike
