Cheap H-Braces
P
Prophet78
Guest
http://cgi.ebay.com/ebaymotors/aw-cgi/ebayISAPI.dll?ViewItem&item=599481082&r=0&t=0#BID1
Auction says it all! I am getting one. I want SFC's now!
-Jeremy-
mailto:p[email protected][email protected]</A>
'93 Red ATX "Red Phoenix"
Rebuilt "Ford Quality Rebuilt Transmission" w/ Shift Kit
SHOShop CAI W/K&N
SHOShop Front STB
190 LPH Fuel Pump
Koni Inserts
Eibach Springs
Blazer Modded Fog Lights
Taylor 8mm Spiro Wires
SHO Filler decals
Fish Tanks
225/50/16 BFG GeForce T/A KDWS
94shoboy
south shore, mass, usa
it looks like 3 pieces of metal welded together :-D the good part is i can have that made in a day for free. that just saved me $100 from SS. thanks for the site
RJ-92
Crappy NYS
ANybody know what the dimensions on one of those are? I plan on making my own SFCs and STBs after the first of the year why not an H brace too
Ron Wazz
Red 92 MTX 109K
ss y-pipe,
dynomax cat-back w/1 superturbo & 1 ultra-flo muffler,
street/strip clutch,
18Lb. fly wheel,
ss tq limiters,
bored out MAF,
UDPs, ported intake
Konis and Eibachs, 26mm RSB
In storage for the winter
FAST4DR
Ditto message above. I bought the H-Brace also and I could have made it myself but not worth the trouble.
William
RJ-92
Crappy NYS
Looking at the pic it looks kinda heavy. there's alot of excess materal on it that could be removed to reduce weight.
Ron Wazz
Red 92 MTX 109K
ss y-pipe,
18Lb. fly wheel,
ss tq limiters,
bored out MAF,
UDPs, ported intake
[email protected]
Albany, OR - USA
But could you remove the weight and still maintain the stability/strength of the brace?
I can't imagine this unit weighing a whole lot, and I'm no engineer, but just from looking at it, if you were to start cutting chunks of it out, I'd imagine you'd completely alter the bracing-ability.
If you're concerned about weight, get someone to fab a solid aluminum or titanium brace. That might be cool.
RJ-92
Crappy NYS
There is alot of steel on there. Although I don't think you'd want to go sawing pieces off her and there, there a few places where you could drill some rather larghe holes in it and still have it provide structural stability. Only about 1/2 (if that) of the metal of it actually is needed to provide its desired rigidity while the rest is just wasted weight.
Ron Wazz
Red 92 MTX 109K
ss y-pipe,
18Lb. fly wheel,
ss tq limiters,
bored out MAF,
UDPs, ported intake
[email protected]
Albany, OR - USA
Again, I'll state that I'm no engineer, but drilling holes in a load-bearing source to make it lighter doesn't sound like a great idea.
But hey, the great thing about this is, if you want one, you can do it, if you want.
Go for it!
1fastsho
Athens Ga
I just welded my control box. It is made of like 20 different pieces of metal spot welded together. I took the welder and ran a bead along the seams. I'm still going to make an H brace but it is really sturdy now.
Shawn Pasley
Innovative Performance Technologies
770-725-4631
www.iptech.tv
92 SHO red/grey
3.2L(bored) Lowered compression(9:1)
stageII cams, Ported/Polished heads,Ported/polished Intake manifold(runners, endtanks, and behind the throttle body), big bore butterflies,80mm maf, LPM,equal length Long Tube Headers and custom Y pipe, Dynomax cat-back, Koni/coil-over suspension, poly-bushings everywhere,26mm FRONT sway bar, 28mm REAR sway bar,rear strut tower brace, solid subframe bushings,subframe connectors, tubular aluminum adjustable rear control arms,shortened shifter,235/45/17 Toyo Proxes T1-S's on TSW VX-1's. 15 lbs of boost here I come!
