brake rotors
lemkea
Grand Haven, MI, USA
i need to get new brake rotors cuz mine are shot and i was just wondering if regular taurus rotors are the same as sho rotors, thank you
ckinart
Mississauga, Ontario
lemkea,
I believe the answer to your question is "no" -- the regular Taurus and SHO have different front rotors. If you have a look here you'll see the two different prices for the non SHO and SHO rotors.
I see in your sig that you plan to keep your SHO stock, but since you're buying new front rotors anyway, have you considered the 96+ front brake upgrade? It's not a great deal more expensive than what you'll have to spend anyway, and makes quite a difference in the SHO braking capacity. Have a look here for details.
Good luck!
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
I belive that the rotors are the same. Just because they have different part numbers doesnt mean they are different. I could be wrong though. The upgrade for 96 is not very expensive at all though if you are gettting new rotors. The only other things you need are calipers and brackets. I think that is it.
K-Dawg
Treasure Coast, FL
Since you have a 95, I highly recommend doing the 96 upgrade since it's so easy and cheap. All you'll need is 96 rotors, caliper brackets, and new pads (598 size I believe).
