another moonroof question
riden2low
Portland, Oregon
How hard is it to take a moonroof out of a wreaking yard find. Found a 95 with a moonroof. It is in the closed position. After replacing my seal I found one of the arms could need to be replaced. Thought of the idea of taking the tracking and glass, motor , everything out and replace my worn parts. Big job? Big Hassle?
lowc
aka vapah lock
Quincy, massachusettes
from what i remember just from pulling out the sun shade its a pita but i could be wrong although i do know that you need to have the roof up to get the glass off
kevinspann
Don't take my advice.
Richmond VA
If you aren't concerned about the wiring harness for the motor, you could cut it, and use a drill battery to operate the sunroof, so that you can get it into the vent position for removal.
Phoenix
SHOHOLIC
QC , Canada
I think theres only 6 philips retaining it (the glass and seal), I always removed it opened though.
I donno if its possible when its closed.
For the rest of the track , its riveted to the body , its alot more of a pain.
riden2low
Portland, Oregon
yeah I think you guys are right. Thought about pulling the head liner out and see if I could get it from the inside. My track arms are ok for now. When I had my glass out I seen a small white plastic chip that came out of the track. It may be ok for now. Just thought I would try to grab the stuff before it went thru the crusher
sperold
Last to Know
And that is a good idea. Maybe take a zip grinder and cut it out, or take a battery drill and drill out all the rivets and see if you can get it out.
I like the grinder idea myself, but you might have to rent it (battery powered).
