ADR Comp 7 wheels
92sho16
b00sted
Liverpool, NY
I believe that is the ideal offset, the stock offset is 42mm, so depending on the tire size you choose it might require some fender rolling.
jedhead
westminster,ca
I wouldn't worry about fender clearance. I would be more concerned with strut clearance if you use tires wider than 225mm.
Bob
92sho16
b00sted
Liverpool, NY
Bob
Ive got 45mm offset wheels and have no strut issues, then again i only have 225mm wide tires.
DemonNeno
SHOCAGO Freak
Skokie, IL
SinisterSHO said:
DOH!! Sorry about that... I just kinda freaked out because this was for an ebay bid. I won, though! Hopefully they'll look good! :)
Silver95
Niagara Region,Canada
Dumb Question-does the offset of the wheels determine how far they will stick out? The higher the offset number, the wheels will stick out more?
K-Dawg
Treasure Coast, FL
Yes.
No. The higher the numerical number, the more the wheels will be tucked in.
SHO Continental
Moderator
Northridge, Cali
Offset if how far the mounting point of a wheel is from it's centerline. Positive offset is toward the outside and negative is to the inside.
MYSHO1
PiCkLe DaNcE!
Wakefield Ma, e.p RI
Im also getting those wheels, i have been following them on ebay for a while, as soon as i sell my other wheels i am there!
DemonNeno
SHOCAGO Freak
Skokie, IL
cool, my order has been placed already. As soon as I get mine, i'm going to test fit 'em and let you guys know how it goes. Also, although I haven't looked much, I can't find the weight specs on these guys. If anything, they'll do so that a 13" brake upgrade can be in order. :cheers:
LeddZepp8687
The Keg Rider
Naperville, IL
Post those up on shocago when u get some rubber on those and have them mounted up. And when you put those 13" brakes on there I HAVE to see those. Big brakes=SEX
DemonNeno
SHOCAGO Freak
Skokie, IL
Yeah, I definitely will! I burnt almost all my Quaife money on other upgrades for the car since there aren't any quaifes to be found. So as far as mounting them up, it'll be a little while. They were just too good of a deal to pass up, though! I'm hoping the car is alive by Feb and completely revamped by April/May.. :corn:
