A new ALSB question
DDakRT
Mississauga, Ont, Canada
I have 2 sets of ALSB, a set of ring and a set of cups from Josh. I remember reading (I'm pretty sure I remember...) that somone mention it would be better to have rings in the front than the cups.
I'm putting the cups in the back because I'm in the rust belt, even though I don't really buy the arguement that the rings are bad.
So should I go with the cups in the back and ring in the front, or a full set of cup bushings for a rust belt car?
Thanks
SHObill
'The Collector'
Rochester MI-48307Detroit
You use what ever u'r most comfortable with! I'll take whats left! REALLY! call me. I want a set to modify! 2 different designs same function. The rings would be easier to modify for me. Only important part is the area that goes through the subframe! It must be tight! the rest is just a spacer/washer!
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
IMO, if your car has any rust at all, use the cup style. They clamp the unibody very similarly to the way that the stock bushings do.
