Saving the planet by not including more pictures?
I thought those came rwd?
Taurus Wagon? Don't think so!I thought those came rwd?
Well, it was supposedly 0-60 quicker, probably because of the extra weight. Doubt it was and quicker beyond 60.I think car and driver or road and track were the only ones to order it. Just type it into google. Only 1 made and it was for them.
https://www.caranddriver.com/featur...istory-of-fords-iconic-taurus-sho-supersedan/
And it was faster then a sedan sho
Talk to a body guy, who knows his way around a welder. Maybe not something you would do in your garage, but a day's work for someone experienced.I did it once on a Sable wagon, just swapped the SHO dash and engine wiring harness and the SHO subframe and engine/trans. Way way less work that sawing a car in half and reconnecting it.
Well, since they were skimpy on pictures, your observation would "seem" to indicate that they dropped a SHO subframe into the wagon. If that's the case, we don't know if they also did the IP swap.Just to note the visual differences, the cornerlights/turn signals on that "sho" wagon belong to a 1994 taurus wagon (or similar year). They are shorter than the sho corner lights... did they just bolt the nose of a SHO onto a wagon and then swap the engine/transmission/wiring to build that?
Looks like that is what they did, kept the front fenders from the wagon and swapped over the SHO front bumper/engine/tranny. They even kept the wagon's hoodJust to note the visual differences, the cornerlights/turn signals on that "sho" wagon belong to a 1994 taurus wagon (or similar year). They are shorter than the sho corner lights... did they just bolt the nose of a SHO onto a wagon and then swap the engine/transmission/wiring to build that?
First I’m hearing that my car was two cars welded together. St Louis Sho James’ , Dad, bought it from a SAAC member who made it.Doesn't seem to be, per someone who had done it years ago. You can use the SHO IP, and all of the electronics forward of the B pillars. I think the comment that @SHOCH made, with the spliced car he had, is that he was just missing the rear wiper wiring, which isn't in the SHO harness.
