'89, Help with Master cylinder question.
quikSHOilver
Yamahaized
Indy
I want to remove the height sensing valve in the back... I am going to use wilwood proportional valve in between MC then run one line to tee in back... I need help on identify which port is primary or secondary on MC...as there are two lines going back... Which port to retain then plug other?
IMAG0435
tinkerkathleen
