REPO007
- Joined
- Dec 2, 2016
- Messages
- 2
- Reaction score
- 1
I need new Pads and Roters on my 2011 SHO. What are some good upgrade options? Looking for something better then factory.
I also own a 2011 non-PP SHO and like everyone else found the brakes to be very inadequate and constantly needing attention. After MUCH searching and reading everything I could on the Forum I recently completed the upgrade that was LONG overdue. The results were outstanding for my needs (I do not track the car but drive “moderately-aggressive”).
There are several options in terms of how far you can go with the upgrade depending on your skill, available free-time and wallet (e.g. replacing all 4 wheels versus front only, PP parts versus non-PP upgraded parts, master cylinder & power booster upgrades etc). I chose to only replace the front brakes and went with 2014 Police Interceptor parts. I chose to use 2014 Police Interceptor for searching purposes as it was much easier to be sure I was getting upgraded PP replacement parts versus non-PP parts. The good news is these larger and vastly improved parts bolt straight in.
There is an extremely helpful link that will run you through the complete procedure:
http://www.ecoboostperformanceforum.com/index.php/topic,5654.msg89527/topicseen.html#new
Replacing the front brakes is very easy to do (MUCH easier than putting in new plugs when I loaded my first tune). There was only one slightly confusing part that had to do with some clips that were attached to the new semi-metallic pads. There is a September 8, 2016 post in the Maintenance section of this Forum that says to break them off but they only need to be bent slightly as they help hold everything in place as you are assembling parts.
There are many choices for parts such as the rotors and pads but I am very pleased with the ones I chose (after doing as much research as I could). The rotors are 352 mm in diameter compared to my stock 325 mm rotors and the non-contact portions are specially treated to resist corrosion. The pads are semi-metallic and the best (for me) compromise between performance, longevity, noise and dust. Most of the parts were purchased from RockAuto with the exception of the DOT-4 LV brake fluid and the brake-hose-to-caliper washers which were purchased directly from Ford. Speaking of the washers, this was the only thing not mentioned in previous posts. I re-used my “old” brake hoses (and hence washers). On my test drive after doing the replacement, I discovered one washer was badly leaking. Don’t make a similar mistake. I believe the washers are included if you purchase new brake hoses.
Here are the parts I chose:
2014 FORD POLICE INTERCEPTOR SEDAN 3.5L V6 Turbocharged
CENTRIC 12065136 Rotors
CENTRIC 30616111 Brake Pads
MOTORCRAFT BRCF208 Caliper
MOTORCRAFT BRCF209 Caliper
MOTORCRAFT BRBC28 Caliper Bracket
MOTORCRAFT BRBC29 Caliper Bracket
MOTORCRAFT EOAZ-2149-B Washers (2pkg)
MOTORCRAFT PM-20 DOT-4 LV Brake Fluid
As mentioned, the improvement is dramatic, very cost-effective and an easy do-it-yourself job you won’t regret.
Yes, the rotors are larger so they hit the "lip" of the dust shield. I simply removed the shieldDid anyone have a fitment issue with the new rotors hitting the backing? Did you have to grind anything off?
