Eric VerValin
PiMPSKiLLET
You gunna buy another drain pan or what.. lol
Ace is a good shop... but I can't say about a repaired one... really dont know anyone who has ever done that before to be honest with ya.
after dissassembly (in the rain, 40 degrees), and reassembly (35 and windy), 2 days worth of working, I forgot to tighten up the battery connections. DOH! I went to go and rev the motor after the engine was warm, when I did, the car died and the lights went out. I was on the phone with bubba1492, He's like check your battery... DOH! I put them back on, tightened them up, and it fired right up. WHEW!
You need to read the posts/replies in your thread better. You're re-asking questions that have already been answered in prior posts in this very thread.
For example, someone gave the (800) number to a mail order company for a new radiator with warranty for $99 dollars, on the 11th (SHOMON). You wasted $44 and tax. Another person posted he had a new one leak right out of the box (SHOZ123). There is no such thing as "old". Either it's leaking, or it's not leaking. Leaking - replace; not leaking - look elsewhere.
Also, ANYTIME you don't get heat output as the temperature begins to rise off the "C" on the temp gauge, the system is significantly low on coolant. So low, that there isn't enough coolant to fill/flow-through the heater core. When it's cold out, you should be able to detect "heat" even if the EATC temp is only set to 72°F . . . .
Oh, and just because the TEMP gauge only showed the temperature in the middle of the NORMAL range, doesn't mean you didn't "cook it". It was in the middle of the range because the temperature probe was no longer immersed in coolant, which meant it was measuring the air temperature. That's when you get intermittent rapid temperature-spikes on the TEMP, as periodically the thermostat opens and intermittently shoots super-hot coolant across the probe. The high-pitched whining noise? That's from the water pump bearings, since there's no coolant to help muffle the sound. And even if you only think you have a leak, never ever leave it unattended for any length of time, much less 30 minutes - unless of course you're looking for an excuse to change the motor . . . .
I'm not "trying" to beat you up. I'm Just trying to show you one of the reasons why you're into this SHO for more than you probably should have been.
You asked for assistance, and then bring-up how much you've spent on the SHO. By not reading all the posts, you're missing valuable information, you possibly delay getting the problem resolved, and in this case spent more than you likely needed to. Personally, I would have spent the 3-5 minutes to verify that the $99 radiator price was still valid, as well as how and where it's shipped from. It's highly possible that it might ship from either Chicago or Indy, and it's entirely possible you would have had it by the weekend.
Fixing most vehicles is a compromise between how much it will cost and how long it will take. If you want/need it fixed right away, you're almost always going to pay much more. If you take a little time to comparison-shop, you will generally pay less for the parts and in turn, less in maintaining a vehicle over time. Also, as you take the time to do the comparison-shopping, over time you will learn by experience who is most likely to have the part, and who's most reliable.
Oh, and trust me. I've got you beat on the stress thing by a long-shot . . . . Just ask Eric.
Two additional points.
If I hadn't mentioned those posts, would you have ever read them?
Second, if pointing out that you overlooked the information helps you better handle the next problem, would you prefer that I did, or didn't?
Personally, my next post following the (800) RADIATOR or the radiator.com posts, would have been a request from others for feedback on product quality, shipping rates and times, and how well the companies did overall.
Thank you. For the most part, I have done some price shopping in on most of the parts on my SHO, just emergency things that keep me from driving it, I get hasty and order/buy where I see it first, or most convienently.
In my shopping experience, you are right, I have learned who is most reliable and who takes a certain amount of time to get things. Generally, 1 item ordered from RCM, takes a day or 2, any more than that, it seems to take weeks. I should have taken those few minutes to call the 1800-radiator place, like I said above, I got hasty.
I figured there were people out there who have more stress than me.
Thank you for your help![]()
Take a chill-pill.
Damn, you worry more than Sam's mother . . . , and she has reason to ! (Sam)
:angelnot:
Glad you got your problem fixed, but ah crud.... I'm a potential member of the radiator cracked end tank club. I've been losing coolant for about a week now. Takes at least a couple days to flag the sensor. I figured it had something to do with me pulling the intake off and fixing my leaking valve cover and rear cam seal. Hoping for a messed up hose, but no. An inspection of the radiator revealed coolant a little more than 3/4 of the way up on the radiator, running down the fan assembly on the driver's side. When you get under the car, it's dripping off the drain ****. Pretty sure the radiator is done.
