Mods
Toolman: Thanks Tim, I don't know if the numbers are corrected or not, they are what was on the screen. I really think a small turbo would work on this setup.
F-22 Raptorsho: If the dyno operator can do that than do we dare believe any numbers ever posted. You don't always have to stay with larger bore and stroke numbers to make power.
40belowsummer: I'll be in Wendover the 13th thru the 17th of Sep. T-BONE steak sounds good.
Modifications: Slightly condensed with a lot of sweat, blood and tears:
Block: The block is a 3.0\183 C/I bored/ destroked to 182.3 C.I. Milled to .005
Pistons:Wesco forged with 3 CC dome, Pin location Dropped. Final measured comp. 11:1
Rods: Casting marks were removed, lightened, shot peened resized,
Crank: Offset ground, lightened heads were ported and polished, bowls blended, 1 mm larger valves, Secondary valves and Rods removed, bored to 40 mm. Intake and Exhaust ports finished to a carbide finish. SS Stage 2 Cams (Cams still need to be timed) Fidenza flywheel (lightened) complete rotating asembly balanced to 55% Piston side, 45% crank
Intake At 400 lift CFM, Intake measured 263.7 @ 2.8 through the manifold, All ports and part opening matched, 65 mm throttle body, 76 MM C&L maf with 55 MM electronics, A/C delete. TB bypass, Underdrive pulleys, SS headers (No cats)
Exhaust Equeal length exhaust into Dr. Gas X Pipes then into Dr. Gas Boom Tube
Engine managment TWEECER
Fuel Red X fuel 112 octane
Tires: 26/15/4.5 Goodyear Eagles, around 18lbs per rim and tire at 70 lbs pressue.
Things can only get better with tuning.
That is a shortened list of the modifications to the car. I can assure you the car is 100% NA no nitrous, turbo or supercharger.
