What is best brand fuel pump & supplier available today?
roswell998
Atlanta, Georgia
I have looked up the following on the web and there is a pretty good variation in pricing.
Comments regarding each and also capacity in LPH of those below where it was not posted on web will be appreciated.
Rockauto.com
Airtex Part # E2001..........$72.99
Appears to be complete assy including float/sender etc.
Capacity not listed
Rockauto.com
AC Delco Part # EP361..........$105.79
Pump, hose, clamps, clips, gaskets/no strainer
Capacity not listed
Rockauto.com
Motorcraft PN PFS180 (F3DZ9H307DA)..........$159.79
Complete Assembly
Capacity not listed
Midwest SHO..........$109.99
Pump, hose, clamps, clips, gaskets, strainer
Capacity = 155 LPH
Advance
Carter Part # P74117
Capacity not listed
Thanks
Cocoa,Florida
i agree i just got my 155 from apeusa.com
they had superfast shipping,great quality walbro for only
$78.00,with free shipping to boot...cant beat that!!!/came with the strainer,hose/clamps,fuel line clips,and o ring for sender unit,most of the time there is no need to replace your sending unit just the pump it self
however if for what ever reason you decide to get a pump from the local parts store make sure there part number differs between the SHO and the regular Taurus SLO
projectSHO89
SHOless In St L
St. Louis, MO
In regards to the Airtex E2001, it is more than adequate for a stock SHO per this email from them:
"Steve,
The flow rate for the E2001 is 30-40 GPH and has a max pressure of
80-100 P.S.I. Thank you for the inquiry.
Craig Gottfried
Tech Line Supervisor
Airtex Products
800-424-7839
Fax 618-847-8678"
IIRC, Bizzy installed one of these and has indicated she was satisfied with it.
It sells for $61.99 at my local AutoZone under the Master brand name and is normally a stocked item.
Steve
sdpatt
Sr. SHO Engr.
Dallas, TX
The Mustang-spec, Walbro 155 lph pump has been doing its job on my car for 200,000 miles. I have a spare on hand, but have been amazed at the longevity of the part.
todras
Grand Rapids, MI
Agreed!
