Your car should make 350 ish hp and 390 ish tq to the tire. Calling my shot.
SM105K is absolutely dead on here! My new tune from Gearhead made more power than my LMS tune and my results were 347 WHP and 398 WTQ on a conservative Mustang AWD Dyno.
I had the same question on the 2011 I bought a few weeks back. The general consensus was that if it had a 3 bar map sensor it was an tuned car. Although I know some of the tuners do offer 2 bar tunes as well. You can look up the map sensor (the one on the top of intake) and if it has a 3 bar type then based on what others said on here its tuned. If you have the previous owner name livernois can see if it's their tune. They do not keep records by vin, which surprised me.So I bought a used 2015 SHO the other day and it felt very fast compared to what I had been seeing online for a stock SHO. I notice an Air Intake from AirRaid was installed and didn't think too much of it since that is usually the first mod a person would do outside of a tune. Well at this point I'm pretty confident it has a tune and maybe some other stuff done to it. I recorded a video of a quick 0-60 run with traction control off on a flat road.
Let me know what you think and any thoughts would be great, thanks!
3 bar on the top of the intake is definitely tuned.I had the same question on the 2011 I bought a few weeks back. The general consensus was that if it had a 3 bar map sensor it was an tuned car. Although I know some of the tuners do offer 2 bar tunes as well. You can look up the map sensor (the one on the top of intake) and if it has a 3 bar type then based on what others said on here its tuned. If you have the previous owner name livernois can see if it's their tune. They do not keep records by vin, which surprised me.
Sent from my SM-G965U using Tapatalk
I think that is a 3bar.I grabbed a picture of the Map Sensor here.
I'm located in northern Maryland right next to Delaware. I'm probably 45 minutes from Philadelphia and I figured there is probably a Dyno there somewhere.
I'm about 20 minutes from Rising Sun in Maryland.Rising Sun MD?
Howdy, kinda neighborI'm about 20 minutes from Rising Sun in Maryland.
BUMPSo how would this work? Get a new tuner, that downloads the "stock" flash (tuned) and be able to switch back and forth?
Howdy, kinda neighbor![]()
I switched to Gearhead this weekend from LMS. I did not have 2-3 shift issues just the 1-2 if I did not turn TC off and also some hesitation in cold weather. Gearhead shifts are a big improvement in smoothness in normal driving and no 1-2 issues so far. Really liking it so far.You been liking the tune overall? I'm shopping around for a new company, I'm tired of the LMS shift issues and useless customer support.
