monkeyboyx
Having an issue with a 2012 MKS, AWD, 3.5 Turbo. Figured this be a good place to start. Rough Idle and surges when holding the brake lightly. Seems to get worse when the weather changes and becomes wet and or humid. Been looking all over the place for possible vacuum leaks. Cleaned a couple of the sensors just in case, still no go. This is what I was able to pull with a VCM scanner. I already replaced the oxygen sensors like an idiot.
Any ideas would be appreciated. Next step I was going to spray some carburetor cleaner and see if the idle changes.
Low Manifold Vacuum on TMAP systems only. (Not sure where to look)
High Fuel Pressure (Interesting but again, not sure)
Air intake restriction (Clean airbox, new filter, air sensor clean, nothing in the air intake)
===PCM DTC P2196:00-28===
Code: P2196 - O2 Sensor Signal Stuck Rich - Bank 1, Sensor 1
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
===END PCM===
===PCM DTC P2198:00-28===
Code: P2198 - O2 Sensor Signal Stuck Rich - Bank 2, Sensor 1
Status:
===END PCM===
===OBDII DTC P2196-C===
Code: P2196 - HO2S11 not switching correctly. Sensor indicates rich.
Status:
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
Diagnostic Trouble Code details
High Fuel Pressure
This DTC may be caused by :
===END OBDII===
Thanks again.
Update: Link to to a video of the rough idle. (7-13-2016)
Status:
===END PCM===
Status:
===END PCM===
Status:
High Fuel Pressure
===END OBDII===
Thanks again.
