I am starting a Zex Nitrous group buy. (I am also looking into the venom kit for some other folks) the kit with at least 5 people to buy is $496. That includes everything. If anyone needs it installed I would do it at my shop for $120 through the group buy.
Check out our website for more info on the Zex kits
www.iptech.tv
Shawn Pasley
Innovative Performance Technologies
770-725-4262
www.iptech.tv
92 SHO red/grey
3.2L Lowered compression(9:1)
stageII cams, Ported/Polished heads,Ported/polished Intake manifold(runners, endtanks, and behind the throttle body), big bore butterflies,80mm maf, LPM,equal length Long Tube Headers and custom Y pipe, Dynomax cat-back, Koni/coil-over suspension, poly-bushings everywhere,26mm Front sway bar, 28mm rear sway bar, solid subframe bushings,subframe connectors, tubular aluminum adjustable rear control arms,shortened shifter,235/45/17 comp T/A ZR's on TSW VX-1's. 15 lbs of boost here I come!
www.iptech.tv
Shawn Pasley
770-725-4262
www.iptech.tv
92 SHO red/grey
