wondering about motor
matty
Southern Cali
just wondering a couple of things have a 91 plus that needs a motor but was curoius if an 89 motor is the same in the department of wiring so that i could just drop it in?:)
SHO M0nk3y
Edmonchuck, Ab, Ca
As far as I am aware of you can swap any 3.0 out any sho 89 to 95 into another. As well has you can interchange the 3.0 and 3.2 blocks.
Someone correct me if I got something wrong.
93rev2sev
Hockeytown
the wiring harnesses on the engine (injectors, alternator, sensors) varies a little from year to year.
Just use the harness off the motor you are pulling. It might mean an extra couple of hours of carefully removing and reinstalling the harness, but it will eliminate the possibility that you get the engine in only to realize the alternator, and some sensors don't hook up.
gtstang1967
BannedInBoston
New Bedford,MA
the 3.2 block with 3.0 head and acc is the best way to go. but yeah the wiring will suck to do but be worth it in the end.
