Widest wheel
TheBigEgg
What's the widest wheel that will fit? I found these Cobra R's w/ the correct bolt pattern at a Tbird site. They're 17x9in. If not, what about wheel spacers and fender trimming?
97 White SHO
UDP, Bullets, K&N, Gutted MAF, No Res, FPS tranny
94 Tbird V8
Stock
stephen newberg
Ladysmith, BC, Canada
Nice looking wheels. I do not think they will go on though. A fair number of people seem to have managed with 17x8, and I heard of one 18x8, but 9 inch is a very wide wheel. Also, are you sure that is the right bolt pattern? 108x5? Also, keep in mind the offset. Max is 45 and that is really pushing it. You can get down to mid 30s or so also, but this all has to be mated with the tire width. As it gets wider, you get less margin for the wheel width and the offset.
If at all possible, you want to avoid spacers. Since they move the center of balance off the intended point for the suspension design, you tend to hurt handling and increase the wear rate of many suspension components when you use them.
Also keep in mind that, as you increase the diameter of the wheel you will need to decrease the sidewall size of the tire or the speedometer will be out of sync. Once you get much lower than 45 on the sidewall for this size tire, there will be very little give and result will be the suspension will be running in full hard all the time. You may or may not want this.
pax, smn
'98, Black
Mod.Porter intake, K&N panel, SARC cutout, instrumentation cluster, 23mm rear swaybar, 245x50x16 Bridgestone Potenzas
ADE 1000
Addison, IL
Check out www.tirerack.com .
Run a search for 17" wheels on a '96-'99 SHO and they list the Cobra R T-bird rim as a choice. They are the same style as pictured, but I doubt they are 9" wide.
A guy at work has a gen II with Cobra R rims, so I know it is possible.
1997 Silver Frost Taurus SHO
- Borla Exhaust
- K&N Panel Filter
2001 Quicksilver Corvette Z06
- B&M Ripper with Momo Combat ****
- !CAGS
CMurderSHO
pittsburgh,pa usa
I have 18x 7.5" wheels and am running 245/40 kumho escta rubber now and I have no rubbing with that combo but There is no way you would be able to use a 9" wide wheel as the clearance from the strut on mine is very small and if I did not have 40 series tires would probabbly rub. One other point I would like to clarify for everyone with the sarc system. I have 40 series tires and it does not put the car into firm mode anymore then when i had the 55 series. I do have the sarc switch and roush lowering springs and the ride with sarc on is still very smooth. Turn off teh sarc and put it into full firm mode and You have much more feel for teh road and you know you have 40 series tires. I have pictures on my site for all that want to see but the tires in the pictures are my old ones which were 225/45 now I have 245/40.
/1996taurussho/
96 silver frost
18" asa js5 wheels
225/45/18 continentals
bullet turbos 3 1/2" tips
open K&N filter
powerslot slotted rotors
superchips chip
asp underdrives
stephen newberg
That is interesting. When I went to the 245x50 series size, the change in the SARC response was very noticable. I had assumed that going to even lower profile would make the effect more enhanced. Perhaps it does not.
They certainly are nice looking wheels though.
pax, smn
'98, Black
Heathcotejosh37
