Wider Wheel Problems
stephen newberg
Ladysmith, BC, Canada
I was over on the V8SHO site yesterday and noticed a modification to the article on wider wheels. Seems Buford (Tim Wright) was trying to put on 7.5 inchers (still 16s) and could not get the 225 tires he had on them to fit without rubbing the struts. This is very interesting, since most of the suggestions I have heard say to go to the 7.5" wheels. Anyone here had any actual practice at wider wheels with various heights and widths of tires? I am still thinking about wider rims to go over to summer and winter sets, but do not want to bother if the fit is a show stopper and I will end up just shipping things back.
Practical results from anyone?
pax
smn
'98, Black
Mod.Porter intake, K&N panel, SARC cutout, instrumentation cluster, 23mm rear swaybar, 245x50x16 Bridgestone Potenzas
It sounds like the wheel he put on had too much positive offset - wheels too far inboard from the hub face. With correct offset (38-45 mm) wheels, there should be no problem mounting 225s or even larger.
On my Gen I SHO, I have 7.5" wide, 35mm offset wheels. This offset moves the wheel too far outboard from the stock position and I had to remove about 3/8" of the inner rear fender lip to fit 225/55-16s on my low riding Gan I fenders.
Scott
SaskSHO
Saskatchewan, Canada
Paul Nimz on the V8SHO list has 16 x 7.5 rims with 245/45 tires and has no problems. Probably has to do with offset.
Scott
97 SHO Black 30k
UDP
Porterized Intake W/K&N Panel Filter
Trush Turbo Mufflers
Firestone SZ50 EP 225/50/ZR16
stephen newberg
Scott, do you have Paul's email? I would like to drop him a line.
pax
smn
'98, Black
stephen newberg
Thank you Scott. I just sent him a note full of questions.
pax,
smn
'98, Black
Heathcotejosh37
