Who Got Flows?
Hochness
Tulsa, OK, USA
Hello to all again!
I am getting Flowmaster Delta Flows put on my 98 tommorow morning and am curious as to if anyone has had any problems with them? I.E. "Service Engine Soon" light or so forth?
Any advice would be much thanked!!
Sam
Sam's 98 SHO Page
wuzzzer
MN Moderator
St Cloud, Minnesota
I don't think anyone's ever experienced a check engine light from swapping out mufflers, or even from removing mufflers completely.
It's sometimes an issue if someone installs a cone filter and the air temperature sensor gets screwed up because of it.
If you want to be on the safe side, after you have them put on, disconnect the battery for a good half hour or so to reset the engine's computer. It might help the computer reset the idle, etc for having less backpressure.
Hochness
Tulsa, OK, USA
Thanks Wuzzer,
I did get a SES light when I installed my K&N Cone filter and it WAS the Heat Sensor just like you said so you hit the nail right on the head there!! Thanks for the advice.
Hopefully I'll be able to get some pictures of the new Flows up on my website soon. But I would like to have a Digital camera first, man they take some sweet pictures!!
Sam
SHODWN
Mother Threasa
Spencer,Ma usa
it wont change backpressure unless he is changing the tips. still the same 1 7/8 hole it has to escape from
Mac98SHO
Pine Island, MN
I beg to differ with you Kirk, Back pressure does change from the restrictive stock mufflers to flowmaster or other mufflers. I will give you that it may not change too much, but it does change. :)
<small>[ March 15, 2002, 08:20 AM: Message edited by: Mac98SHO ]</small>
wuzzzer
MN Moderator
St Cloud, Minnesota
Don't bother arguing with Kirk. Just leave him alone and eventually he'll go away. wink j/k ya man. thumbs_u
Seriously, if anyone has any questions on DIY stuff, check with Kirk first. He's torn his car apart and put it back together more than probably everyone who owns a Gen 3 combined.
<small>[ March 15, 2002, 02:15 PM: Message edited by: wuzzzer ]</small>
Hochness
Tulsa, OK, USA
Got my new Flowmaster Deltas put on today! Also had the resonator removed and a straight pipe put on in its place. Man what a difference in sound!!! I can barely hear my K&N Cone Filter anymore. I did get a SES light about 10 min. after picking up my car from the muffler shop. When I got home I realized that the ***** at the muffler shop messed with my air temp sensor and tried to put it back into where I had it but didn't get it in all the way. So I reinstalled it back into where I had it and disco'd the batt. cable for about 30 min and haven't seen the light since, but then again I may have to wait a few days to see if it comes back on. Anywho, I love the new sound!! Hopefully I'll be able to get some new pics up on my website for ya'll to drool over!!! j/k Sam's 98 SHO Page :)
SHODWN
Mother Threasa
Spencer,Ma usa
Thanks Mark :) Im not trying to know it all but you gain very few ponies if any- and the exhaust is still pushing through the same 1 7/8 hole. Mac is right back pressure will change but only where it collects. IE>> stock mufflers let it build up in the pipes before the restrictive muffs. now your getting in to the **** with backpressure cause of the flows. But its still has to exit through the tiny ass ports designed with the system. Mark what size are your tips? normal **** size lie 2" or 2.25?
stephen newberg
Ladysmith, BC, Canada
My vague memory of Boyles Law tells me that Kirk is correct. Without chnaging the size of the appetures in the container, and leaving the starting incoming pressure the same, there cannot be a change in the resulting outlet pressure. Ain't physics fun! :)
pax, smn
SCOTTDW
Memphis, TN, USA
I noticed a quicker response after the 1st shift when I installed performance muffs and a panel filter last year. Love the V8 rumble even if the increase is only imagined.
Scott
98SF
K&N Panel
Magnaflows 3"tips
BFGoodrich KDWS
Hochness
Tulsa, OK, USA
I kept the same tips that came with the car, I didn't want to loose them, they be cool! I haven't noticed too much increase in power, now that I've had a chance to open 'er up on the highway. But man, do I love that V8 sound. It's not the sweet sound of a Mustang Bullitt or anything, but it does make them Honda's with the 10inch tail pipe sound like doogie!! lol
Sam
Sam's 98 SHO Page
wuzzzer
MN Moderator
St Cloud, Minnesota
I'm probably imagining things, but my car felt faster after I had my new muffler tips put on. Especially in the 2500-3500 1/2 throttle area.
LASTSHO
MinneSHOta
wuzzzer:
You're probably not imagining things...if they helped the backpressure a bit...it probably increase power a bit....ever so slightly.
These cars are HORRIBLY sensitive to backpressure.
mholhut
MA
I felt an increase in power just from swapping motors! LOL
Heathcotejosh37
