White smoke coming from turbo area
evt
georgia
2011 Taurus sho with 180k miles
Hey guys,
So I just finished up replacing my turbo oil lines and have everything installed back into the car, filled it up with oil and was in the process of starting a coolant refill when I noticed white smoke with a plastic smell coming from the top of rear turbo. I followed the instructions given in the manual I bought from E-manual online, “fill the reservoir to an inch over cold fill line, start and run at 3500 for 30 seconds, let idle for 1 min, turn off and let sit till cool. Check reservoir and fill if necessary. (I didn’t notice a change in fluid level even after the initial run) Then idle till operating temp and fans kick on so you know the thermostat has opened.” The fan never kicked on and after I gave it a few revs the temp gauge started rising from operating temp. I turned the car off when the temp gauge reached 3/4 of its readout (1/4 over the operating temp). The smoke was persistent throughout this process but diminished in volume from the initial step. I used all new crush washers and coolant line bolts along with both new oil lines and hardware. Torqued everything down to spec per the manual I purchased. I don’t know if this is fluid burning off from when I disconnected the lines, because I did not drain either the coolant or oil prior to trying to remove the turbo. It wasn’t until after I got a face full of coolant that I drained the engine of both fluids during the repair. I would like thoughts?
evt
georgia
You should pressure test the system to check for leaks.
The best way to fill the system is by vacuum filling.
i got you, what tool would u recommend for doing both of these operations?
I just started up the car again and there was no sign of the white smoke or burning plastic smell
raymo23
