White '89, 3.3 HC, Tri-Flows...
-DVP-
NaNaaNaNAAAA!!!
0 .· ` ' / ·. Full Retard
White '89
HC 3.3l engine
Tri Flow cams
Extrude Honed runners
Big bore butterflies
SHO Source equal length Y pipe
Borla Cat back
Rod shifter w/shorten handle
96 brake upgrade with Carbotech XP10 pads
New wheel bearings
Reinforced diff?
Southbend stage II pressure plate
Fibertuff 9 puck disc
Tokico Struts, new mounts and end links
Moog springs -1
SCT chip
80mm mass air
Fender CAI
Police grille
NOS Ford headlights
Body is fair at best. Paint is ******, chalky, body has some dings, touch of rust in the drivers dog leg, and under the gas door.
Interior is OK, Seats/carpet are low mile gen 2 stuff. The headliner and moonroof cover need fixed. The dash has one crack in it.
Car needs some ironing out, but runs and drives as is. I would recommend trailering it, as I haven't put many miles on it since I bought it. But the car runs/drives.
To finish it, it needs a tweecer or quarterhorse, and a tune, bodywork, paint, and a headliner. Selling the motor wrapped in a decent shell.
$2250
Dont need it, dont want it, needs to go away, NOW.
