bittertech
1990 SHO, 3.0l 249k miles, 160k on the engine, 60k service (minus valve shims) done ~20k ago.
In the last 3 months by buttdyno tells me I've lost 20 horses. It doesn't pull as hard as it once did, especially before the secondaries open up -- and when the secondaries open up, it doesn't slam you back into your seat like it used to, just pushes you. The engine used to be freakishly strong, crisp on the acceleration -- its still pulls strong, but just not what I remember.
I ran seafoam thru the intake, new fuel filter. O2 filter was replaced when we did the 60k (we did an engine swap at the time) -- Plugs, wires, Crankshaft position sensor, 02 sensor. Apparently I've got a leak coming from the camshaft covers but I'm waiting to do a valve adjustment before I tackle that.
Think I might've broken the front motor mount recently too (also replaced during the engine swap), shifting has gotten sticky (especially in 1st and 2nd) and I noticed the engine had some play on an emissions dyno today.
So.. short of a compression test, any ideas what I could check out?
