Wheel bearings
Sloboatsho
I was wondering if anyone has replaced wheel bearing hub on there sho and what brand did you use. Thanks in advance
AFAIK, people have used OEM/Motorcraft, a few have used Timken. OEM doesn't seem to last very long, no idea on Timken longevity. I hear if you can get SKF bearings they have the lowest return rate in the industry. May be worth a try.
Sloboatsho
Does anyone know the size of the front axle nut? Going to do it tomorrow just want to make sure I have all the tools. Thanks
For the 2010:
FRONT & REAR
Install a new wheel hub nut.
  • Tighten to 350 Nm (258 lb-ft).
abs99
CT
I got sick of having to replace the OEM Ford wheel bearings on my car after I had 3 failures. I went ahead an replaced all 4 with Timken. Fuel economy instantly went up and no issues with them in the last 40k miles. Highly suggest Timken aftermarket and not Ford wheel bearings.
SHOinVa
Tidewater Va
Is this a problem, I have a 2012 with 5ok so is this something I should be concerned about. When I bought the car I didn't see anything on the Carfax about them being replace. I don't drive the car that much but it is a road trip car so do any of you think this is something I should do as a preventive maintenance. I see from abs99 that Timken is a good brand any others out there and how much do they usually cost. LOL I seem to have a lot of questions today, I just never thought if this as an issue. Hope your having a great day.
SilverSH0
I have almost 80k on my original wheel bearings, no issues.
Johnbigdog
michigain
How many of you that had low milage repeat failures torqued the axle nut to spec with no weight on the bearing?
Just curious.
