What is that sqeaking???
Machspeed
Former 1991+ owner
Santa Barbara, CA
Its when im at lower speeds. Theres this sqeaky noise, sounds like its comming from the front. Ive heard it on my friends 4.6 Tbird. Can someone help me. I have reasonably new suspension.
Check the tie rod ends first. You can **** the OEM rod ends by using a hypo type basting needle to inject grease into a small *********** in the rubber boot. Replacing them works too, but you will need the toe-in reset after putting them on.
Speedy_91_SHO
Toledo, OH
I had this problem too. It did it around 20 MPH, only at that certain speed. It turned out to be the backing plate was rubbing on the brakes. Very easy fix, just bend it back. Hope this helps
