What are the Syptoms of a Failing TPS?
stevetatro
Cincinnati, Ohio
Hard to pinpoint all the possible symptoms. You'd probably feel some hesitation in the throttle.
There's a way to test whether or not your TPS is acceptable.
You backprobe the middle (I think) TPS wire and measure the DC Volts (VDC) with the key on but the engine not running. Some people fiddle with the TPS position (by using the play in the screw holes) to get the VDC at idle to read as close to 1.0 as possible without going over. 0.96 is a good target.
Also, you can check to make sure the TPS is working properly by watching the VDC while slowly opening the throttle. The VDC should rise smoothly, and never dip back down towards zero.
If these two criteria are met, I'd say your TPS is functioning properly.
If you can become close friends with a person at AutoZone (or wherever) maybe they'll let you try out a new one to see if that fixes whatever ails your SHO.
Good luck.
aaronsbiza
Sacramento, California
Then again, my SHO has 70K and as far as I know it hasn't had a 60K. It just seems that the gas pedal should be a little tighter to the accecleration curve. How relevant is the 60K as far as spark plugs to the performance of the engine. I have removed the plugs and they all look to be only a little worn, not enough to misfire. Then again I could be wrong.?
SHO--ripper
928 Euro
winsted,CT
usually a bad TPS would cause a very jumpy idle. Also, You should replace your plugs and wires. That seems to be your problem. Try a new air filter either K&N or Kool Blue. thumbs_u Hopefully that will solve your problem.
stevetatro
Cincinnati, Ohio
When you checked the plugs did you actually re-gap them? Also, did you make sure there was no carbon tracking (not sure of the technical name) on the plugs? This has caused problems on a few SHOs.
FIREMT1977
