I understand the Cardone #571373 rebuilt water pump is the front part only, and it includes the gasket to go between the front and back. My question is can the front piece only be changed without removing the whole unit from the car? Is it necessary to remove the whole unit to do the timing belt and CPS? Seems to me it would be better if I can just leave the back part alone because of all the problems I've read about o-ring leaks when it is disturbed.
Actually, when we did the water pump, the belt looked pretty good...not new, but good.
