Have not done a compression test yet, but will soon. Plug is all gunked up and power is down. There used to be a LOT of smoke on startup, but not so much now. I do not see how valve seals could cause the plug to become coated with this hard coal-like substance, but who knows. I did a search, and still did not come out with a sure idea of what it might be. ranger told how to tell the difference with a compression test, but any other ideas would be appreciated.
Also, can the rings be change without removing the heads? I can not remember how much clearance I have from underneath, but I am doubting I can pull (or should for that matter) the pistons out from below.
And last, how difficult to replace valve seals and guides? I have other heads I would just as soon put on if the job is too big and expensive.
TIA guys (BTW, this is for a customers car, not the turbo
