Black-taurus
I posted a while back about a weird wobbling noise coming from the valve cover. i ripped into the front of the engine replaced the timing belt. when i started the car up the noise was gone yeay. then it came back a month later. now I was probing around with a stethoscope and it sounds like it was coming from the valve cover. Seamed like the rear. could this be the problem. the rear valve covers leak like an sob (the front ones do to but technically they only leak from the galleries the rear leaks from the side valve covers.) it leaks around the chain. I was resealing the valve covers and giving the car new plugs. i had just finished the front one and began to torque the valve cover bolts on the front to 12 ft-lbs when on the third bolt from the left (the top one) POPed. snapped the damn bolt. probably snapped at 11 ft-lbs. anyway I need the car to start school monday. I'll be going to school then work Monday-friday from 9-9 so I need this damn rattletrap to get to school. so i grabbed some high tack gasket and some black rtv sealant and stuck the bolt back in there. put the car back together with only new wires and new front valve covers. ran it tonight and it isn't leaking oil. I know it will eventually leak oil. so I need to go back in there anyway next saturday. point being... if there is a problem with the valve cover I'm ripping it open anyway what should I look for. the inside of the front one looked brand new.
also the car when put back together still bogged like an SOB. i assume it is mainly the spark plugs that help this problem.
thanks again guys
thanks again guys
