valve clearance check
sho'noff
shoverdrive
the land of the setting s
how many miles before the valve clearance check should I expect to wait? what is normal? typically how difficult would it be to adjust them?
from what I understand the valve shims from a big 4 kawasaki kz would work, is that correct?
kevinspann
Don't take my advice.
Richmond VA
My car has 125k on it and it isn't a concern...if I need to pull the intake for something I'd consider checking them, or if the valve cover gaskets are leaking, that's a good time to do it too.
I too have checked numerous engines and most of them were still in spec. I never had to change more than 2 shims on any one engine.
I even changed cams in one engine and only had to adjust one shim after doing that.
they are quite stable and its really not something to worry about. its easy to check when you are doing the 60k work, and maybe you need to adjust one or two and maybe you don't.
yes they do, and yes there is a special tool to do it (actually a pair of tools.)
AREA 91
PA SHO SHOP
Area 91
It just depends on the engine. The Yamaha is a very high quality engine with tight tolerances. Most of the time the shims are within spec.
If you are going to look for shims locally, the shim diameter is 29mm.
sho'noff
shoverdrive
was replacing the spark plugs in hopes of having enough time to check the comprehenssion and i found that 4+ year old spark plugs need to be replaced sooner than 30k miles.
sho'noff
shoverdrive
when I looked into the cylinder with a flashlight the piston had a round spot that looked like it was cast onto the top of it. about half the size of a dime, I wonder if that is normal?
there is a small round spot on the top center of the pistons. most likely yours has a bunch of carbon buildup on it, which is not desirable.
sho'noff
shoverdrive
no, it is on all the cylinders that i looked at. actually about 13mm diameter upon closer peering. weird, like a mini piston top crop circle.
sho'noff
shoverdrive
may not need the valve adjustment I changed the plugs and it runs fine on all 4 cylinders.
that is why one should not post after their fourth beer of the night....
AREA 91
PA SHO SHOP
Area 91
That is cast into the piston from the factory.
Nothing to worry about.
