URGENT!: GEN 2 Sub-Frame Compatibility. . .
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Will a GEN 2 SLO Subframe, work on a GEN 2 SHO? Today coming into my parking lot, there's a slight L shape turn (turning left into the bottom of the L), I applied some throttle and as went to turn right the tires began to slip, and the car pretty much jumped the damn curb. The whole rim literally caved in. I immediately stopped the car, and noticed that there was oil leaking on the floor from around the subframe bushing. When I got it to the shop, and put it on the lift, you could see where the lower control arm meets the subframe had bent in. I purchased a 92 SLO subframe from a local yard, but i'm not to sure if it will work on the SHO. Any insight as to where the oil could of been coming from? It was engine oil. Also, when I shift it from park to gear the engine pretty much jerks. . . . . never done that prior. This is just about the worst thing that could of happened at the most unfortunate time, but I'll go bankrupt before I let that car sit and rot. So far I'm $400 into this mess (pretty much what I paid for it), $300 labor, and $100 for the subframe. I definately need new endlinks, lower control arms, and possibly the inner and outer tie rods. My axles have less then 2,000 miles and I hope I can salvage them.
Talk about one of the worst days of my life. . . :frown:
Frantzdy
SuperHO
Mental Patient
St. Joe, MI
:oogle: That don't sound too good......check your clearance between your subframe and oilpan....then check and see if the oilpan itself is cracked....if you went up on the curb that hard, it's possible. As far as I know, the SLO and SHO subframe are NOT compatible with each other...but I've been wrong before.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
SolidState said:
All Gen 2 ATX subframes are the same. The only different subframe is the MTX, and is interchangable from 89-95.
That's very relieving.
I checked the oil pan, and it "seemed" fine. The oil began dripping as I jack the car up from the front. Then it stopped dripping, and hasn't dripped a drop since. I also had a slight antifreeze leak as well. I don't think I went that far onto the curb to reach where the oil pan was, because it almost immediately after hitting the curb drop down onto the pavement. I just hope all goes well, with a minimal blow to my pockets tomorrow. I'll find out just how bad it really is once we get the subframe off. Thanks for your responses! Much appreciated.
Frantzdy
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Just thought I'd drop in and give an update. The subframe came in yesterday after 6 hours of waiting, and the measurements came out to be perfect. So it seems, we'll have to drop the y-pipe in order to remove the subframe. . . . I snapped a couple of pics with my camera phone but none of the actual subframe. I'll take some of that when I get there shortly.
704472039 ORIG
You can see from this angle where the bottom of the tire is inward.
704472038 ORIG
704472032 ORIG
704472037 ORIG
704472035 ORIG
Not the best pics, but just an idea.
Frantzdy
Racer X
SHO Pilot, Retired
Connecticut
Where is the other end of that chain tied to? I hope not the intake, because it won't hold the weight of the engine and transmission.
And also, you don't really have to drop the Y-pipe; you can snake the subframe up and over. It's not the easiest thing in the world to do, but thats what I've done in the past.
Where are you getting the work done?
Shoaz
Studly dood
Scottsdale, AZ
Belt lift1
Belt lift2
That's a piece of seat belt tied through two runners and around the fork on the lift.
I don't recommend this at all, but in this case it held up the entire subframe and drivetrain assembly.
I'd definitely not use the tanks to hold anything up, if that's what you meant.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
706057906 ORIG
Old SubFrame . . . . . . .
706057901 ORIG
Trans mount. . . . .
706057899 ORIG
Another view. . . . .
Honestly, I'm not exactly sure we he had the other end tied to. The work was done at a local shop down here in Brooklyn, Hamal. He had the old subframe out, and swapped in the new one in less then 1 hour and a half. It turns out the oil that I saw leaking from the subframe was infact coming from the tranmission mount which was damaged. The biggest pain of the job was inserting the strut rod into the lower control arm, and having the LCA line up properly into the spindle. Took us 30 mins to realize that I needed a new spindle and strut. So to recap. . . . .
LCA - $45
2 endlinks - $44
SubFrame - $100
Tranny mount - $35
Spindle - $50
KYB Strut- $50
O2 sensor - $43
Labor - $300
Alignment - $65
4 GEN 3 Chromies - $303.24
Yep, marvelous way to spend over $1,000 in two days. Lastly, are the GEN 2 SLO, and SHO front swaybars the same? What I've noticed different about the car is the steering is very hard. VERY hard. Thanks for all the answers through out this ordeal, it's feels good to be on the road again.
Frantzdy
SolidState
No Mo SHO
Toronto, Ontario, Canada
They are interchangable, but not likely the same diameter. I can't really see the sway bar causing front steering stiffness.
Perhaps you damaged a tie rod or even the steering rack?
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Perhaps your right. Would a damaged tie rod prevent an alignment from being within spec? Also, what other indications should I look for in a damaged steering rack? Again, thanks for the response!
Frantzdy
SolidState
No Mo SHO
well, that fluid you found could be from your power steering rack. Alot of SHOs use ATF as PS fluid. And a damaged tie rod could indeed cause alignment issues.
SuperHO
Mental Patient
St. Joe, MI
Your allignment could also be off due to removal of the subframe....even using proper subframe allignment guidlines, you'll still have to have it straightened out.
but yeah, a bad rack will definitly cause stiff steering....
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Actually the fluid I saw leaking was dirt black, which I assumed was motor oil which turned out to be some type of liquid oil that they put in the transmission mount.
Wait, I'll have to have the subframe straightened out? I'm not using same one that took the hit, or it doesn't make a difference? Also i've made two some what important oberservations yesterday. . . . . . .
1. On a flat surface, the car drives straight. On a surface leaning toward the passenger side, the car pulls to that side and the same goes for the driver side. . . . . . .
2. In all the excitement of getting the car back, I didn't realize that two different types of endlinks were used for the sway bar. Passenger side plastic, driver side metal. Could that be a cause of what I mentioned above? The steering seems to be stiff when the car starts pulling to one side, meaning having to hold it at a position where it doesn't pull.
Frantzdy
SolidState
No Mo SHO
no, this is starting to sound more and more like an alignment issue.
I would definately get matching sway bar links on there, doesn't matter if thay are composite or aluminum, just make sure they are the same.
Lastly, you'd be surprised at how dark PS fluid could be, especially if it has been in there a while. Not saying that it IS definately PS fluid, but still check the fluid levels of the PS system.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Ok, sounds good to me. I'll pick up another set of sway bar links, and throw them on. And while I'm down there I'll check the PS fluid level. Thanks for the help!
Racer X
SHO Pilot, Retired
Connecticut
Frantzdy, on the pulling issue on off camber roadways, mine does the same thing. Even my old 93 Police Package did it. On the SHO, I have new LCA's L/R, new tie rod ends L/R, new inner tie rod R, and new struts, springs, and mounts all around, AlSFB's with no play, and it still will pull if the road leans left or right.
The only thing is does need right now is new swaybar bushings, but other than that the car is tight.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Guess I'm 7 hours to late. . . . I picked up a set of sway bar endlinks. Guess I'll hold on to them, or maybe even have you drive the car one of these days and you tell me what's what. Sooooooooo, who wants to help me identify the culprit that's causing a grinding / rotational type noise. . . . :biggrin:
Frantzdy
93SHwagon
Mississauga,Ontario
Will an 89 subframe bolt up to a 93 slo?
The 89 will have the engine and tranny on it,I just wanted to know if the 4 main bolts that hold the subframe to the body will be the same.
