universal multiswitch
nc89sho
S13 Sellout
Clemmons NC
anyone have a procedure for changeing the little "smart stick" on the stearing colum? it's the thing for turn signals ect. i have to change mine in the mourning and would like the job to go smooth as i have to work later.
Shoman594
Moderator
Lockport, IL
Not too hard, First take out the screws at the bottom of the steering colum, shouldbe about 5 of them. the the bottom part should come off and then you can lift up the top piece, at this point you should be able to see the multifunction switch. there are 2 bolts one at the top one at the bottom there are also 2 plugs that you need to unhook. at this point just put it back in the way it came out. Good luck!
Those two bolts holding the switch on (at least on the year SHOs I have done this on) are Torx headed bolts. You will also have to unscrew the tilt lever using pliers or a small open end wrench. Nothing unusual in this change out.
Bizzy
Yes, I'm bringing a totally old topic back up to present but I have a couple of questions. When you guys replaced the MFS, did you guys remove the ignition tumbler or can that really be left in place?
Also, how long are the stupid screws that hold the shroud in place? Mine turn and turn and turn and turn.....but they don't come out. Are they supposed to stay in place in the shroud? The shroud doesn't seem to be getting any more loose than it did when I first started turning the screws. shrug
TIA thumb
haydenm315
Reisterstown, MD.
Bizzy:
</strong>
Sorry I can't answer the question, but I advise in being careful when taking out the tumbler. Everything can fall apart in your hands. Everything being the springs and pins that make up the lock. That happened to me once and I almost had a panic attack. I needed to get the car running shortly after I began screwing with things. It was kinda tricky, but I managed to get it right with not too much sweat. If you've gotta remove the top shrowd, you will need to remove the tumbler. sdpatt said the bottom, so maybe you're lucky.
Bizzy
haydenm315:
Bizzy:
</strong>
Thanks for the response Hayden. I'll keep that in mind when I take it out. Honestly though, I've come to expect things such as that, good thing I'm handy at putting things such as those back together. :) I hope I do get lucky. Tomorrow during the daylight will be a better time to work on it anyway.
wink
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Beth, there are also snaps in the corners of the 2 Covers for the column, thats why they really dont seem to be getting any looser. In my Gen 2, there are 3 screws underneath, and one on the very corner on the lower front passenger side.
I recently did this, so if you need any hints, I can probably give you some bad ideas. thumb
Bizzy
ROFL! Yeah, tell me what not to do and I'll be sure to do them. :) burnout
DHMag
Free At Last
InCahoots, Texas
the screws prolly stripped in the cover, thats why you turn and turn and turn and they dont get any more loose. only remedy ive found is to yank it apart and hope i dont break the cover apart. to reassemble, fill the hole with super glue then immediately thread the screw in (while off the column). leave it set a few minutes, then remove the screw, and viola...new threads. and also hope you dont get the screw stuck in the hole...cause that blows. another option is use wood glue and a toothpick. put a few drops of wood glue in the hole, insert toothpick, let dry.
the tumber has to be removed to remove the column shroud. just put the key in, turn to KEY ON/ ENGINE OFF, use a small screw driver or allen wrench, push up on the pin, and pull the cylinder out. it comes out in a nice little package. ive never had any worries about the cylinder coming apart on me. when reinstalling, the cylinder only goes one way. if ya have to force it, its the wrong way.
I have replaced the multifunction switch several times on my car and others and I have never had to remove the ignition tumbler. There is enough clearance as the top and bottom column covers will "clamshell" far enough open to allow you to remove and replace the switch.
<small>[ January 21, 2004, 12:00 PM: Message edited by: sdpatt ]</small>
Bizzy
Thanks for the info Scott.
I did end up getting the switch replaced. The tumbler came out with no issues. I was unable to remove the two screws in the right side of the shroud, the left side came out with no issues but I was unable to remove the shroud completely. I just pried the shroud open far enough to allow the switch to be removed. No big issues.
Yes, a torx bit is required to remove the switch, it's a T-20 for those who might need to know this in the future. Once I got those out the switch came free, popped the connectors off, put them back on the new switch, put it back in place and wham bam thank you ma'am, Bizzy has headlights once more. naughty
Thanks much to Bryan King for sending me a switch out and for giving me a few pointers. You da man Bryan! thumb
<small>[ January 21, 2004, 12:18 PM: Message edited by: Bizzy ]</small>
bradman
Everett, WA
sdpatt:
I think the "shroud" around the column is different for gen 1 and 2. Gen 2 requires the ignition cylinder to be removed to get enough access to the MFS. Cylinder comes out pretty easy though, as DHMag has explained.
Bizzy
bradman:
Actually, it came out so easily it was almost scary. :)
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
bradman:
sdpatt:
What he said... there was no way I was gonna get to both bolts and the wiring with the top cover on.
Glebtihonniaqw
