two stripped valve cover bolt threads.....
llamaking122
Green Machine
Columbus, Ohio
so i went to finish up my job today and i stripped two on the rear bank. Hadnt even put any pressure on them and i walked them in by hand.... What can i do. I heard about putting a little jbweld in there just i dont want my car shit rigged
Phoenix
SHOHOLIC
QC , Canada
Hammer the top of the allen holes , then hammer your allen back in for a really tight fit.
That trick never failed me.
RAYJAY
WHO ME ?
UNION DALE PA
you have to heli coil them you need to get a kit to match the thread of the bolts drill tap and install the insert
firebat45
Edmonton
Helicoil, it's not a hack fix, it's a standard method of putting strong steel threads into aluminum. It works great for repairing stripped bolts, too.
Phoenix
SHOHOLIC
QC , Canada
not the allen holes the head threads btw i didnt mean to put this in the performance section
Yea well I missed the last word of the title of the thread. :booboo:
True , even brand new 302 alu intakes or heads comes with helicoils already in them.
Supposebly helicoil is stronger then any stock threads (in alu).
RAYJAY
WHO ME ?
UNION DALE PA
How to Repair Threads With A Heli-Coil Insert
[YOUTUBE]http://www.youtube.com/watch?v=RFYa6sjhh_E[/YOUTUBE]
jimtash
nc
Stay away from the Heli-Coil and go with EZ-LOK instead. Much simpler to install and this is coming from experiencing the same thing you are. You're looking for a M6 X 1.5mm thread pitch insert.
http://www.ezlok.com/Home/index.html
RAYJAY
WHO ME ?
UNION DALE PA
is there a enuf metal for the ez-lok or did you use the thin wall ones ??? i use the heli coils all the time and never have a problem at all :nut:
jimtash
nc
Plenty of meat there. I used the regular inserts but thin walls are fine. As long as the hole for the insert itself stays around the 8mm range, it should be fine as far as holding up.
The reason I like these is because they are solid inserts and easy to install. And they work. With Heli-Coils, you need the tool to insert it and break off the tang. These thread in with a regular screw driver. And sometimes the Heli-Coils have backed out on me. These don't because they're coated with Loctite.
newshofan
chattanooga, TN
Reviving this due to im experiencing the same prop with a striped bolt in my timing cover..im losing oil like mad tired of buying oil and the mess and smoke...i tried an ez out and said scew it..so now im paying for it. I plan on drilling out the bolt.... im not sure if to use heli coil or the ez lock. Like stated ez lock looks easier but which kit should i get. Someone point me the right direction here. Need this fixed asap.
