Turn signals acting goofy
91WhiteSHOpa
PA, Usa
My SHO sat for a couple months, and when I took it out for a run, I noticed that nothing happened when I turned on either turn signal(no flash, no click, nuttin).
I swapped out the entire combination switch off the column with one from my brothers crown victoria(same switch.... Except maybe not activating the turn lights[turn lights, different from turn signals])..... So now the right turn signal works right most of the time, sometimes the left turn signal works, other times only the back light turns on, other times not.... Very seemingly random. Any ideas what might cause this?
I'm lookin at gettin this baby inspected mighty soon...
Thanks,
air12290
Denver, CO
I had similar problem with my 93 ATX.. no signals, no flashers.. fuses were fine. I finally replaced the flasher relay that is under the dash above the emergency brake, and the relay that is attached to the brake pedal. Now, everything is fine.. total price.. about $8
myculito
