Turn Signal/Climate Control Broken
kelderman94
Wisconsin
1992 Taurus SHO - 5spd
Everything was fine last night. I went to leave this morning, no dash lights, no climate control, no turn signals, nothing. Checked fuse number 6, which relates to these things, it was burned out. Replaced it, but nothing changed. Checked it again, and it was not blown. What can I check next?
Shopower400
Atlas
Electric City, NY
Do you know if the EATC (climate control) has been replaced? (say with a HB; hard button one?) It's possible that one of the plugs on the back could have come loose, although unlikey.
As far as your headlights go, check your dimmer switch. I know i've left mine all the way down, which will pretty much give you no dash light. If it's not that I would check the headlight switch ($20 new) and also check the rest of the fuses. I do believe that there are several fuses that run the things you're describing:salute:
Satchmoz
