Turbo SHO HOW-TO...
rocket455
Fairfield, Ca
ok heres a list:
-48#injectors
-255lph pump
-shonut fuel regulator sys
-good tune
-custom alum intake pipes/Ti exhaust pipes (i get it for free :)
-custom free flowing exhaust is going to be fab'd
-not sure what turbo i woudl be aiming for
im sure i have the supporting mods to take full advantage of my set up
-3.2 mtx
-80mm MAF
-BBB
-Freshly rebuilt heads
-10.4mm Taylor plug wires
-UDPs
-Stage 1 cams
-Aggressive head port job
-Polished bowl
-oversized valves
-gasket matched intake plenum
now with this set up, i am looking for a safe 350+whp. what kind of turbos should i be looking for?
Sho Amo
SmkTyresntDrugs
Olney, Md
Haha, I forgot about the sticker. But yes, remember, 21psi is only a starting point. I really want to get this thing tuned for race gas and big boost, so I can go down to Tx and set a standing mile record before I sell her.
sounds good. i think your motor has taken the most boost than any other sho. 22psi is alot already.
and rocket: with all the stuff your planning 8-10 psi should net you more than 350 with the right tune.
BlackonBlack89
burlington county,NJ
I remember a certain turboSHO with a broken W/G line seeing more than 20psi. I also remember that car hauling ass:dribble::rofl:
Thanks again for that ride.
TT SHO PROJECT
OHIO
my interest was in the tuning aspect of the car. i need to have it tuned next week. i live in northeast florida. ive been to a shop called stage six motorsports, they told me they have done a turbo sho before, they have more imports than anything but do have mustangs and ford gt's. i just need to tune it next week somewhere good.
Stage 6 motorsports?? :eek: if i recall they are the ones who made the twin turbo 1400hp ford GT!! if so yeah take it there!!!!
munkee
Too busy...
Missoula, MT
Is sizing the fuel pump as simple as injector size times six? Or did my brain not boot up properly this morning.
93rev2sev
Hockeytown
2 choices really...
155LPH (good for all boltons...not enough for boosting over 10PSI...no pressure regulator needed)
190LPH (good for whatever you can throw at it...needs Pressure regulator).
munkee
Too busy...
Missoula, MT
Ok, yeah I got it now. I was thinking both injectors and pump as lbs./hr. Hey Tim, I was curious how that turbo spools? Or did you go with a different A/R? Which turbo are you planning on using in your next build?
Toolman
Boost it!
Grand Lake, Oklahoma, USA
2 choices really...
While a 190lph will flow a lot of fuel, it will be on the ragged edge for some FI cars making more than 450whp. Keep in mind that a 48lb/hr injector means just that. In one hour, at 100%, it will flow 48lbs of fuel. So all 6 will flow 288lbs/hr. One liter of fuel weighs about 1.6lbs. So a 190lph pump is rated to flow 304lbs/hr of fuel. And since the BSFC of FI engines is generally higher than that of NA engines, I would be wary of cutting my fuel supply system so close. I would say that a 190lph pump is plenty for 42lb/hr injectors and smaller. Anything larger and a 255lph pump would be wise. It is always good to have some margin built in.
It is for sure slower spooling that the previous turbo, and as such, the boost comes on slower, which equates to less TQ (same hp though, around 390whp for 14psi, but 30ft lbs less tq).
I currently have a T66 with a fairly large A/R. It will spool even slower (which should be a little easier on my gears), but should be able to make a TON of power up top, as I want to rev this next engine to 7500+rpm.
ArkanSHO
Arkansas
John at D & P
Dropped by to say hi to John and he started talking about how SHO people are such a different breed, especially after meeting you (Tim) when you picked up the completed pipe order.
BlackonBlack89
Tim did you just say you are starting the next turboSHO!!!!!!!!! Holy ****. he's back
Hey tim I know you have the full size T66 already but did you ever look into getting the hybrid version of it( I think the A/R was .63 on the turbine). It would be the best of both worlds. One more Q is this turbo going to be a BB turbo???
quikSHOilver
Yamahaized
Indy
Hot pipe
Tim, Thanks for the hot pipe... its awesome!!! Now I can really start to visionalize what my set up would be!
:woohoo:
sbsho
Spokane, WA
yeah they did, its pretty sweet lookin. from what i heard the guy got beat in a race with his ford gt while it was stock, so he upgraded to twin turbo
somedude_001
Western NY
becasue they want to keep it a secrete. So we can bitch about people not searching.
with how cheap 255lph pumps are (same price if not cheapier than 190lph or 155lph) go with the 255 they are about 80 bucks why mess with it for that money just get the big one.
it is the same story with the 48 lb injectors. don't go smaller like I did because you will likely end up upgrading it later because boost is like crack. 10psi felt good 15 will feal even better... and it does :)
Toolman Tim, thanks for your great work on this. After studying this for some time, I'd like to summarize what I think the collective though is - can you let me know if this is correct?
For a real budget setup, a guy could use the stock engine (including mafs, fuel pump, and injectors) and run around 5-7 psi, getting close to 300 chp or around 250 whp, using a fmu or reprogramming the pcm. (Would this need to be intercooled?)
The next step up, cost-wise, would be the limit of stock internals at around 13-15 psi, which would require larger injectors, mafs, and fuel pump and fpr, along with reprogramming the pcm. This type of setup could produce over 400 chp or over 350 whp (maybe more?) if properly tuned and intercooled.
For over 15 psi, the stock pistons need to be replaced with forged ones at somewhat lower compression ratio, and over 20 psi is workable.
Somewhere, better cams become important - would that be more than 10 psi? More than 15?
Now here's another question - has anyone set one of these up with a draw-through throttle body rather than blowing through it? (I hate blow-off valves...)
Keep up the good work!
BlackonBlack89
Yes tims current setup is drawn through. I guess the tunablilty is better
The BOV is needed anyways blow-through or draw-through.,
The BOV is there to blow off extra be slammed into the TB when it slams closed in decel, shifts, ect
Boost on the stock setub is a joke really
SASHO91
Zoom Zoom
San Antonio,TX
Tim and I went over this, and his thoughts were about the same as mine.
5-6psi on the stock injectors(i'm using modified 3.2's), bigger pump (155-190), a bigger MAF(Pro-M 75mm is what i'm using) would prove to be better, a small or adj. FMU (something on the order of 4:1 or 6:1), and a small intercooler for hotter climate cars.
Should keep things within the safe margin and prove to be very fun and very reliable.
Re-read his statement.
And I agree, boost on a stock setup is a joke. However, tweak it alittle and IMHO your'e set.
Toolman
Boost it!
I think 7psi non-IC'd is certainly workable. Not ideal, but workable.
Sounds pretty spot on.
I have never used anything but stock heads/cams. Would cams and head/work net me some nice power? Surely, but for the cost, I would rather just enjoy what I have. Making power all the way to redline with the stock stuff now, but it would be interesting to see what kind of gains head work and cams would give.
I believe Josh T has a drawthrough TB in his S/C'd application.
WaltJ
