Trying to put it back together
MorpheusGPR
Ford TRIO
Indianapolis, IN
I have a bitter sweet sho vac line kit now and I am trying to get this upper intake put back on.
What lines hook to the secondary units? I can't find any place to run anything too?
Thanks.
Do you have the vacuum diagram on under the hood some where?
AREA 91
PA SHO SHOP
Area 91
I believe that the 2 lines from each set of butterflys, "T" together, abd then go to the canister on the back of the intake. You also have a line that runs from the intake (near the alternator) that runs to the fuel pressure regulator.
MorpheusGPR
Ford TRIO
Indianapolis, IN
Ok that makes sense, I have 3 lines in my bittersweet sho kit that I have hooked to a T now but I am not finding another T to run to the two butterflies. I hate when I can't get stuff back together...makes me wish I had never taken it apart.
MorpheusGPR
Ford TRIO
Indianapolis, IN
No it just came with lines, no further comment on that.
I hope to get this back together, I want this all done soon if I keep the car.
MorpheusGPR
Ford TRIO
Indianapolis, IN
Some quick pics I just took:
I also double checked my miles...it is just over 131k miles I was off.
ohfosho
ontario SHOwner
ontario, canada
the best way to change the vac lines is one at a time when you have the new ones...you should be able to find a few decent pictures with color vac lines so you are able to map them out.
DVJ38
Hartford, CT and Worc, MA
Hey nice pics! What percent tint is that? Limo (5%), 10% :shrug: It's too dark for my tastes, but looks awesome. I'm trying to figure out what percent tint I want front and back. Those valve covers are very bright!
Sorry I didn't help at all... :p
LeddZepp8687
The Keg Rider
Naperville, IL
There is a black plastic assemby mounted on the back of the runners, the single line goes into that, If i rember correctly it is a black canister style thingy. Im gonna see if I can find u a pic online somewhere.... Good luck for now!
Here I made you an image of where tha vac line goes....Hope it helps!!
my.php
MorpheusGPR
Ford TRIO
Indianapolis, IN
I can't access your page at work :( I will take a look tonight. All the help I can get would be great. Its been down so long I thought about getting a decent 97 to use as a driver and then just take my sweet time on this 94 until I get it done. Not sure I would really want to pay insurance and tags on 4 cars though, 3 rapes me bad enough.
LeddZepp8687
The Keg Rider
Naperville, IL
Link works for me on 2 computers, Once you see my pic though you will know exactly where to put that vac line. Good luck!
MorpheusGPR
Ford TRIO
Indianapolis, IN
Pic works at home, it was not the pc or the link just the work filter...something in the link it did not like.
I will go out and see if I can figure it out, that canister is loose and moved in my car...so I will have some extra work to get it placed.
